Date/Time: Wed, 19 Mar 2025 03:28:45 +0000
TPO Range (session high/low) extension lines
View Count: 679
[2022-10-10 04:46:00] |
Whacky - Posts: 3 |
Is there a function to create extension lines to highlight the range of a TPO session on the TPO chart? Essentially I am looking to plot the high/low of that session in a similar way to how the value area, POC, singles prints, etc can be plotted? Photo to demonstrate request. Thanks |
[2022-10-10 16:28:36] |
John - SC Support - Posts: 38782 |
The High and Low of a TPO are just the high and low of the time period that the TPO covers. Therefore, you can use the Daily OHLC, or the High/Low for Time Period or High/Low for Time Period Extended. There are other studies as well that you can use to get the High and Low, it really just depends on how far forward you want to extend the lines and the time period of the TPOs. Refer to the following for the above mentioned studies: Daily OHLC High/Low for Time Period - Extended For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
