Date/Time: Tue, 26 Nov 2024 14:46:35 +0000
Backtest
View Count: 962
[2014-05-20 10:09:03] |
User35749 - Posts: 32 |
Dear Sir or Madam: I have an account with InfinityFutures and I am currently a paid subscriber for Sierrachart trading platform. How can I backtest a trading strategy such as SMA50 cross above/below SMA200 will be long/short position and EMA15 cross above/below SMA50 will be entry/exit position? Thanks, Van |
[2014-05-20 14:39:51] |
This can be easily done by using the Spreadsheet System for Trading study: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#GeneralInformation And then using the back testing feature: http://www.sierrachart.com/index.php?l=doc/doc_Backtesting.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-20 14:40:57] |
Or you could use ACSIL for this: http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
