Date/Time: Wed, 19 Mar 2025 03:22:37 +0000
New to SC- possible to zoom in/out using mouse wheel?
View Count: 1153
[2022-10-09 11:32:09] |
User328450 - Posts: 2 |
thanks!
[2022-10-09 12:35:21] |
Sierra_Chart Engineering - Posts: 18836 |
Yes refer to: General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
