Date/Time: Thu, 20 Mar 2025 02:11:49 +0000
Total Volume
View Count: 548
[2022-10-08 17:44:04]
User412994 - Posts: 15
Is there a way to display total volume ON THE PRICE CHART for each candle when using Numbers Bars (Renko in ticks)? (Not as a study below using Numbers Bars Calculated values, Ihis is what I'm using now). I would like it displayed at the top or bottom of the candle if possible. I can't find in any of the settings or in documentation. Thanks in advance!!
imageNB Chart.PNG / V - Attached On 2022-10-08 17:41:53 UTC - Size: 86.66 KB - 163 views
[2022-10-08 21:11:48]
Sierra_Chart Engineering - Posts: 18846
This study can do that:
Study Subgraph Above/Below Bar as Text
It needs to reference the main graph in the chart, and the Volume Subgraph of that.
Date Time Of Last Edit: 2022-10-08 21:13:53
[2022-10-09 13:08:57]
Can't believe I couldn't find that...thank you so much.
