Date/Time: Wed, 19 Mar 2025 02:20:15 +0000
ACSIL Function to Add Custom Shortcuts to the Drawing Shortcut Menu
View Count: 472
[2022-10-08 17:09:47] |
fykemang - Posts: 49 |
Is it possible to add custom shortcuts to the drawing shortcut menu similar to how we can add custom shortcuts to the normal chart shortcut menu with sc.AddACSChartShortcutMenuItem ?The use case for this is I have some custom chart shortcuts but also make drawings on my charts. I also receive pointer inputs for some of these custom chart shortcuts, so when I accidentally hover over drawings and right click I would like to be able to call those custom chart shortcuts as well. |
[2022-10-08 21:09:57] |
Sierra_Chart Engineering - Posts: 18836 |
Global Settings >> Tool Settings >>General >> Display Chart Shortcut Menu with Chart Drawing Menu. This is in the newer versions of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-08 21:10:04
[2022-10-08 21:18:34] |
Thank you for the tip, but this does not also display the custom shortcuts I have added with sc.AddACSChartShortcutMenuItem.
[2022-10-08 22:15:09] |
Ok we will look into that and make sure that is supported.
[2022-10-09 18:06:07] |
This will be supported in the next release.
