Date/Time: Wed, 19 Mar 2025 02:15:52 +0000
Incosistent results of Developing VPOC using
View Count: 457
[2022-10-07 21:15:04] |
User396 - Posts: 55 |
I am noticing that Developing VPOC by "Volume Value Area Lines" is inconsistent with VPOC value provided by volume profile. The value provided by Volume Profile is correct. But often times Developing VPOC by "Volume Value Area Lines" is incorrect. I have attached a sample screenshot for AMD for the month of Jun-22 vpoc by volume profile is 86.90 but 80.83 by "Volume Value Area Lines". There are many other places these prices do not match. I have also attached my settings for "Volume Value Area Lines". What am I doing wrong? Is there any other study I can get developing volume POC? Thank you, User396 Date Time Of Last Edit: 2022-10-07 21:20:03
[2022-10-07 21:24:19] |
John - SC Support - Posts: 38782 |
You should be getting the same results. So there is something different in the setup. The most probable is the Ticks per Volume Bar. On your Value Area Lines study this is set to 1. Is it also 1 on your Volume by Price? Also is the Volume by Price study set to the same monthly periods and are they not referencing any periods back (reference periods back - 0)? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-07 21:38:50] |
Awesome, Thank you for quick response!!! It was my mistake and an easy fix. Volume by Price had different tick per volume bar. I read help page three times and still I missed it. |
