Date/Time: Mon, 21 Apr 2025 23:30:23 +0000
Price Column Graphics
View Count: 2028
[2022-10-07 14:27:50]
Steve Leon - Posts: 312
I am following up on previous inquiry regarding two graphics related features related to the price column on the Chart and Trade DOM and also to Time and Sales
1) Right now there is no way to limit the number of digits visible in the DOM or Time and Sales Column. One way could be if you would be able to narrow the width of the price column (like you can with some of the other columns) or have an input for the number of digits displayed.
2) If the would be a way to show traded prices at the start of a session by reversing the colors/graphics at those prices.
Not sure if something like this is already available through a custom study or if you could make any suggestions
Thank you
[2023-02-15 15:18:47]
I am following up on this question.
Is there anyway that you would consider making the following changes to the price ladder graphics. (Just as an aside I am part of a Discord group where mostly everyone is using Sierra Charts and several members voiced these same wishes)
1. To highlight the previously traded price on the price ladder by shading it a different color or reversing the color. Similar to the display that TT uses.
2. Being able to either limit the number of visible digits on the the price ladder or narrow the column so only the desired digits can be viewed .
Thank you very much for you help.
[2023-02-15 16:49:36]
John - SC Support - Posts: 39395
#1 is a Feature Request. We have noted it, but we can not say when we can get to any particular request.
#2 has some functionality implemented for it. Refer to the following:
Chart Settings: Limit Price Displayed to N Right Characters (Chart >> Chart Settings >> Display >> Chart Display Items menu)
[2023-02-16 13:28:47]
Thank you very much. I was able to change the number of digits displayed on my price column and the associated time and sales.
On the price column I am not able to control the size of the price column using the red tabs at the top of the DOM columns in order to make it smaller or larger. You are able to achieve this on the other columns. Am I correct in saying this ? Would consider adding this feature to the DOM's in order to make the columns as narrow as possible and take advantage of being able to reduce the number of digits in the column.
Thank you again
[2023-02-16 17:55:18]
That is what we meant by "Some functionality" for what you were asking about for the Price Ladder. You can not change the size and even with the fewer digits displayed, it does not shrink down to fit that particular data. This aspect is another Feature Request.
[2023-02-16 17:58:33]
Thank you for your consideration of these requests
Best
