Date/Time: Wed, 19 Mar 2025 02:29:31 +0000
indicator Bid & Ask Depth Bars of orderbook
View Count: 452
[2022-10-07 12:56:07] |
User158392 - Posts: 1 |
hello im trying to join you because i would like a second trial to test an indicator wich is Bid & Ask Depth Bars, with Difference (Bid - Ask): Total Bid Quantities - Total Ask Quantities. Is it possible ? Also does this indicator display the total current pending orders of ask side less the total current pending orders of bid size of the orderbook ? Thank you
[2022-10-07 15:40:46] |
John - SC Support - Posts: 38782 |
We have activated the trial for your account. The Bid and Ask Depth Bars has an option of Cumulative Difference. Refer to the information here: Bid & Ask Depth Bars To see the actual Total Bid/Ask you would need to use a different study, such as the Numbers Bars Calculated Values study. Refer to the following: Numbers Bars: Displaying Numeric Information Below Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
