Date/Time: Wed, 19 Mar 2025 03:28:45 +0000
New version update
View Count: 389
[2022-10-07 12:53:15] |
User342483 - Posts: 1 |
Hi, is there an option to receive email update for new version? It so can you guide me?
[2022-10-07 13:02:36] |
Sierra_Chart Engineering - Posts: 18836 |
No there is not an email notice for this. You just need to check the homepage of Sierra Chart: https://www.sierrachart.com Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
