Date/Time: Wed, 19 Mar 2025 03:28:45 +0000
Teton Order Routing Chart Trading- Parent/Child quantity mismatch
View Count: 442
[2022-10-06 19:14:34]
Christopher Hine - Posts: 10
Hi I have just started using the Teton Order Routing service. When i use the chart trading and input order with attached OCO stop/limit orders I get the correct quantity for the parent order but the child orders show 0 quantity, please see attached images. Do you have any suggestions on how to correct this?
Many Thanks,
Chris
imageSierra Screen Shot 1.jpg / V - Attached On 2022-10-06 19:13:33 UTC - Size: 129.47 KB - 106 views
imageSierra Screen Shot 2.jpg / V - Attached On 2022-10-06 19:13:56 UTC - Size: 117.33 KB - 109 views
imageSierra Screen Shot 3.jpg / V - Attached On 2022-10-06 19:13:59 UTC - Size: 64.62 KB - 100 views
[2022-10-06 20:59:23]
John - SC Support - Posts: 38782
The Child orders are going to show 0 until the parent fills. Once the parent fills, then the child orders will show the quantity.
[2022-10-06 22:23:11]
Ok great. Thanks for your help.
