Date/Time: Tue, 26 Nov 2024 14:32:39 +0000
GateKeeper is unreachable
View Count: 1259
[2014-05-20 08:23:08] |
User33743 - Posts: 83 |
Hi, I can't login into live environment. MSG LOG shows "Gatekeeper is Unreachable". I checked and login into sim environment works good. What can i do? |
[2014-05-20 08:25:19] |
Please contact TransAct support about this: http://www.transactfutures.com/ContactUs.htm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
