Date/Time: Wed, 19 Mar 2025 02:31:43 +0000
Message Log for review USDJPY
View Count: 395
[2022-10-06 17:51:21] |
User664561 - Posts: 33 |
The message log has been sent - is continuously running attempting with errors, to load live data on the symbol
[2022-10-06 20:51:34] |
John - SC Support - Posts: 38782 |
Your drive is full, therefore you can not download any additional data and the system is unable to find the most recent data. You need to free up space on the drive on which Sierra Chart is installed. Refer to the following instructions to find unused symbols, and note the information at the end about how to then delete the data for those old symbols: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
