Date/Time: Wed, 19 Mar 2025 02:31:40 +0000
Can't connect to Rithmic
View Count: 434
[2022-10-06 15:16:40] |
opmetal - Posts: 71 |
Hi, According to instructions from my broker I should be connecting to: System: Rithmic 04 Colo Gateway: Colo 75 ...but there is no "Rithmic 04" in the dropdown list of servers in Data/Trade Service Settings. How do I set this up? Thanks. |
[2022-10-06 15:28:14] |
John - SC Support - Posts: 38782 |
The list of Servers for Rithmic actually comes from Rithmic. If you are trading normally (not through a prop firm) then you would want to select one of the Rithmic 01 servers, whichever one is closest to you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
