Date/Time: Tue, 15 Sep 2026 15:43:58 +0000
Open order - cancelled brackets, how to put back again?
View Count: 592
[2022-10-06 14:03:05]
User58008 - Posts: 32
I´d like to know - is there a possibility how to put back the SL and PT brackets/orders when once cancelled? For example when I accidentaly remove them/cancel them and the position is naked, can they be put back in order way then putting them back through the chart trade menu?
The reason why I am asking is that sometimes I am a bit confused what type of order to use for stoploss and for profit target when the position is Long/Short, isnt there a button to get them back with a predefined distance, like points from the entry order?
Thanks a lot, Luke
[2022-10-06 15:17:23]
John - SC Support - Posts: 47898
Refer to the following order type:
Order Types: Send Attached Orders - Position/Price
