Date/Time: Wed, 19 Mar 2025 03:40:14 +0000
MArket data
View Count: 314
[2022-10-06 13:13:41]
User805208 - Posts: 1
Hello, I am unable to receive market data to my SC software. It has worked fine then suddenly it stoped, after I reset it, it opens the latest data but its static there, it doesnt move.
[2022-10-06 13:19:23]
SC Support - Posts: 1943
Hi User805208, please provide us with the Message Log, thank you.
Copy and paste the *entire* copy of the Message Log into your email message or Support Board message according to the instructions below. Sending some of the lines is not helpful. The entire Message Log is needed. The Message Log does not contain any private information.
1. If the Sierra Chart Message Log is not already open, then select "Window >> Message Log" on the menu to open it. If you still do not see the log after selecting this command, then select "Window >> Reset Windows". The Message Log will be displayed in this case. If not, then select "Window >> Message Log" again.
2. Press the "Copy Log" button or use "Edit >> Copy Entire Log" on the menu on the Message Log window. This will automatically copy the Message Log to the system clipboard. Do not use the "Send for Analysis". Otherwise, the log will not be seen.
3. Move your Pointer to the message area either in the email message, Support Board or Account Support Ticket.
4. Right-click your Pointer. Select "Paste" on the menu to paste it into the message area.
