Date/Time: Wed, 19 Mar 2025 09:42:08 +0000
Fairx exchange Product not supported
View Count: 702
[2022-10-06 02:12:24] |
User127441 - Posts: 3 |
I am using Teton connection to trade, my broker is Edge Clear and clearing house is Dorman, and i want to trade Fairx product, my broker told me that sierra chart doesn't support Fairx now, so they can't help me to set. and i have check the support board and found Sierra chart have finished the Fairx development, so i want to know what happened? thanks very much.
[2022-10-07 19:12:12] |
Sierra_Chart Engineering - Posts: 18841 |
We will get back to you on this. We will be going over it internally next week. We can add support for FairX easily on Teton order routing through Dorman. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-07 19:12:36
[2022-10-20 04:39:10] |
hi, any update for this issue? thanks
[2022-10-21 15:50:45] |
Regarding FairX, we have decided to move on to other projects.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-21 15:51:07
