Date/Time: Thu, 20 Mar 2025 04:31:10 +0000
Simulated Futures Trading Service
View Count: 446
[2022-10-05 18:45:12] |
jrob - Posts: 22 |
If I purchase Service Pack 11 with the Denali feed, can I use the Simulated Futures Trading Service and\or the Trade Simulation with real time data before connecting to a broker \ trading service?
[2022-10-05 21:37:50] |
John - SC Support - Posts: 38812 |
The normal answer would be "No, you can not do this, as you need to connect to your live trading account in order to get the real-time data for the CME Group at the non-professional rate". But, we see that your account has been connected to a trading account and your verification end date is November 3, 2022. As such, you are now getting real-time data from the Denali Exchange Data Feed for the CME Group, so you can use the Simulated Futures Trading Service with the real-time data through at least November 3, 2022 (sometime before then, you will want to connect to your trading service again to continue to be able to get the CME Data at the non-professional rates). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
