Date/Time: Wed, 19 Mar 2025 02:26:50 +0000
Chartbook not compatible warning
View Count: 477
[2022-10-05 18:38:46]
michael carpenter - Posts: 2
Hi I am getting the following error opening a chartbook: Chartbook not compatible warning, Contact Sierra Chart support for help with converting it.
How do I fix this?
[2022-10-05 21:32:39]
John - SC Support - Posts: 38782
Either follow the instructions here:
Chartbooks (Workspaces): Opening Older Chartbooks
Or attach the chartbook to this thread and we will update it for you.
[2022-10-07 17:04:30]
File attached to be converted to be compatible with the latest version
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-10-07 16:59:36 UTC - Size: 276.18 KB - 193 views
[2022-10-07 17:26:57]
Attached is the updated chartbook.
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-10-07 17:26:54 UTC - Size: 20.56 KB - 121 views
