Date/Time: Wed, 19 Mar 2025 03:42:15 +0000
Break Even Button
View Count: 1065
[2022-10-05 17:27:12]
Technical - Posts: 158
I have set up a DOM with a break-even button set to "Trade Move Stop to Break Even".
When I activate that button the it either moves the stop off the visible DOM or closes the position altogether. Can you tell me what I am doing incorrectly?
Thank you.
Private File
[2022-10-05 17:58:18]
John - SC Support - Posts: 38782
There is an offset that is applied to the Move to BreakEven. Refer to the following:
Basic Trading and the Trade Window: Set >> Move to BE Offset
You probably want to set this to 0 to start and ensure that the Move to BE option works as expected.
[2022-10-05 18:19:07]
On my trade window, the Move to BE Offset is set to 0. I tried setting it to 1, no change. It moves it to 38.00. See enclosure.
This is acting as if the "Move to BE Offset" was a high negative number as it goes way off screen.
I am on 2439 by the way.
image2022-10-05 13_15_52-Trade Orders.png / V - Attached On 2022-10-05 18:18:43 UTC - Size: 69.61 KB - 181 views
[2022-10-06 16:18:43]
Sierra_Chart Engineering - Posts: 18837
Provide us that chart you are trading from, following these instructions:
[2022-10-06 17:12:42]
Ok, this is the chartbook I use, it supports the DOM.
Private File
[2022-10-07 10:02:26]
We do see a problem with this and we are looking into the cause and will resolve.
The problem relates to this new requested feature variable:
AlwaysUsePositionAveragePriceForReferencePriceForBreakEvenCommand
It did not support, a chart Price Multiplier other than 1.
Date Time Of Last Edit: 2022-10-07 10:06:40
[2022-10-08 13:32:22]
Am I understanding that this may be incorrect? Please see screenshot.
image2022-10-08 08_30_35-Symbol Settings.png / V - Attached On 2022-10-08 13:32:03 UTC - Size: 42 KB - 138 views
[2022-10-08 17:20:09]
The default Symbol Settings are correct. There is no issue there. The issue is resolved. Update to the latest prerelease.
