Date/Time: Wed, 19 Mar 2025 03:42:19 +0000
CME Direct - Market data is not showing from 5:00PM CST till 8:30AM CST NEXTDAY
View Count: 379
[2022-10-05 15:59:16] |
bala - Posts: 74 |
Hi, CME closes daily for one hour (4:00PM to 5:00PM). I used to see the data from 5:00PM on wards. Now Sierra charts does NOT show data between 5:00PM till 8:30AM next day. Am I doing something wrong or has anything changed. I use TETON CME direct. Could you please clarify? Thanks |
[2022-10-05 16:43:57] |
Sierra_Chart Engineering - Posts: 18837 |
Check the session times: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
