Date/Time: Wed, 19 Mar 2025 03:26:46 +0000
Cannot replay chart
View Count: 479
[2022-10-04 21:22:26] |
bigdollarkc - Posts: 21 |
I cannot replay chart anymore. It was working fine this afternoon but when I tried to do it later in the day, It would just reload the chart and when I clicked PLAY, it would just reload again and nothing is moving. Please help.I attached a log file below
![]() Attachment Deleted. |
[2022-10-04 22:02:06] |
John - SC Support - Posts: 38782 |
How are you defining where to start the replay? Have you set a Use Start Date Time on the Replay window? Or did you scroll the chart back to where you wanted to start? Also, are you replaying multiple charts or a single one? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-05 00:50:35] |
yes I set the time and date on the replay window. I started with single chart on my 15 secs chart. I also tried it with my 1 min chart. It wouldjust keep reloading the chart when i pressed PLAY. I updated my sierra and tried it again but the result is still the same.
[2022-10-05 14:12:07] |
Can you please get us a screenshot of the Replay Window so we can see how this is set?
[2022-10-05 23:26:35] |
I retested it today and it is working fine already. Below is a screenshot that I attached
Private File |
[2022-10-06 09:29:37] |
Sierra_Chart Engineering - Posts: 18836 |
So we understand that you are not currently having an issue?
[2022-10-06 10:40:57] |
No the issue has been gone. Thank you for your support
