Date/Time: Tue, 18 Mar 2025 23:21:53 +0000
RE: Footprint chart has candles on chart
View Count: 619
[2022-10-04 13:37:50]
User648702 - Posts: 48
All of a sudden my footprint chart has a large candle in front of each footprint. Why did they appear and how do I get rid of them. All candles same color and pretty much same size.
[2022-10-04 16:37:06]
John - SC Support - Posts: 38782
There are several options available within the Numbers Bars Study to put a candlestick or markers along with the numbers. Refer to the following (and the 4 items after it):
Numbers Bars: Open and Close Marker Style
It is also possible that you have a Study/Price Overlay that is putting the bars back on the chart. You will want to check your studies to see if this is the case.
If you still can not figure it out, then we need to see a screenshot of your chart to be able to understand what it is. Refer to the following for how to take/attach a screenshot:
