Date/Time: Fri, 25 Sep 2026 11:33:50 +0000
sc.GetTimeHMS() Stopped Working
View Count: 1376
| [2022-10-03 20:14:00] |
| Tony - Posts: 725 |
Working with the SCDateTime Variables and Values: GetTimeHMS() The error message I got is this: error: ‘struct s_sc’ has no member named ‘GetTimeHMS’ please help, thanks Date Time Of Last Edit: 2022-10-03 20:22:17
| [2022-10-04 15:28:17] |
| Sierra_Chart Engineering - Posts: 24971 |
Show us the original code because that function does not exist on the sc structure. It is a member of SCDateTime objects.
| [2022-10-04 17:10:17] |
| Tony - Posts: 725 |
thanks, what I am trying to do is play a sound when market open at 6:30 Eastern. this is the code gave me the error message: (tried SCDateTime::GetTimeHMS(6,30,0) too, didn't work) if (sc.BaseDataEndDateTime[sc.Index].GetTimeInSeconds()==sc.GetTimeHMS(6,30,0)) sc.PlaySound(7); this code works as I expected (): if (sc.BaseDataEndDateTime[sc.Index].GetTimeInSeconds()==(6*3600 + 30*60)) sc.PlaySound(7); |
| [2022-10-04 17:23:01] |
| Tony - Posts: 725 |
Thanks, I figured it out, this should be the correct way to use the function: int a {0}; int b {0}; int c {0}; sc.BaseDataEndDateTime[sc.Index].GetTimeHMS(a, b, c); and a, b, c, being updated as last price changes. I vaguely remember there was a function, takes inputs of numbers of hour, minute and second, and converts them to the value of TimeInSeconds. |
| [2022-10-04 18:45:48] |
Use this function to get the current time: ACSIL Interface Members - Functions: sc.GetCurrentDateTime() Also refer to: Working with the SCDateTime Variables and Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-04 18:47:21
