Date/Time: Tue, 18 Mar 2025 23:24:17 +0000
A meter and an alert on volume bars
View Count: 430
[2022-10-03 16:59:44]
User266447 - Posts: 270
Is there a chance tp see how many contracts are left before a volume bar will be closed? - maybe there is a meter that counts contracts fulfilling a bar or how many contracts are left before the bar will be fulfilled?
Secondly, can I set an alert (rining) when a volume bar is closed?
Just in case I attached a print-screen of my chart and indicators I placed already on the volume bars chart.
imageVolume_bar.png / V - Attached On 2022-10-03 16:59:34 UTC - Size: 79.35 KB - 107 views
[2022-10-03 21:16:11]
John - SC Support - Posts: 38782
The Countdown Timer study will do this. Just add it to a Volume based chart and it will show the remaining volume for the current bar. Refer to the information here:
Countdown Timer
To alert when the the current bar is closed each time, open the Chart Settings window and go to the Alert tab. Enter the following for the alert:
= 1
This means the alert is always active. Then set the following options:
- Evaluate on Bar Close = Yes
- Reset Alert Condition on New Bar = Yes
Choose the Alert number you want for your alert.
