Date/Time: Sat, 12 Sep 2026 03:16:15 +0000
Problems changing from CQG to Denali datafeed
View Count: 784
[2022-10-02 12:50:41]
User930625 - Posts: 9
Is there a tutorial? Say's I have acct. but system will not allow further progress in setup. Thank you AC103728
[2022-10-02 23:30:43]
Sierra_Chart Engineering - Posts: 24841
You are already using the Denali Data Feed. Are you referring to using the Teton order routing service?:
Who is your broker?
[2022-10-03 08:56:37]
AMP is broker. CQG is my data feed. I tried to change to Package 10, Denali feed with Teton order routing without success on my new computer. My old computer with CQG seems to work.
[2022-10-03 10:33:59]
You cannot use Teton Order Routing with AMP. You need to use CQG only.
