Date/Time: Fri, 11 Sep 2026 17:36:36 +0000
Question
View Count: 748
| [2022-09-30 16:00:39] |
| User418765 - Posts: 2 |
Hello I would be trading the Gold futures only Can you tell me which package I need to purchase to carry on in sim mode trading Gold I would like mose economical probable 12 months or 6 months Thank you |
| [2022-09-30 17:36:26] |
| John - SC Support - Posts: 47848 |
If you are going to be using simulation only, then we recommend using our Delayed Streaming Data, as this is available at no extra cost as long as you have usage time available. You can also use our Simulated Futures Trading Service with the delayed data. If you are going to use the delayed streaming data, then you would want to be on one of the Base packages (package 3 or 5). Refer to the information at the following link: Description of Service Packages and Pricing: Base Packages If you want to have real-time data, then you would need to be on one of the Integrated packages (packages 10, 11, and 12), which allow access to the real-time data. Refer to the information here: Description of Service Packages and Pricing: Integrated Packages Just be aware that if you want real-time data and you want to pay the non-professional exchange fees, then you need to be able to connect your Sierra Chart to a live, funded, futures trading account at least once a month. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
