Date/Time: Tue, 18 Mar 2025 17:33:20 +0000
conectar amp a sierra chart
View Count: 462
[2022-09-29 14:48:22]
julianted - Posts: 1
hola, tengo cuenta con amp y recien compre la licensia 10 de sierra chart, podrias ayudarme a conectar mi cuenta dfe amp con sierra charts para operar en vivo y no con datos retrasados? muchas gracias
[2022-09-29 15:49:21]
John - SC Support - Posts: 38768
From Google Translate:
hello, I have an account with amp and I just bought license 10 of sierra chart, could you help me connect my dfe amp account with sierra charts to operate live and not with delayed data? Thanks a lot
Most likely AMP has set you up with CQG for your order routing. If this is the case, then you will need to follow the instructions at the following link to connect your Sierra Chart to your CQG account:
CQG Trading Platform Service: Setup Instructions
