Date/Time: Tue, 18 Mar 2025 17:33:20 +0000
Interactive Scale Range
View Count: 423
[2022-09-29 13:09:57]
obee2732 - Posts: 11
I am using the Interactive Scale Range setting. I notice that when I click, hold and drag the y-axis upwards, the height of the chart shrinks/squishes, and when I drag downwards, it expands the chart.
I am wondering if there is a setting to reverse this?
Secondly, I have set my Scroll Wheel setting under GUI to be "Wcroll Wheel Changes spacing normal. with "shift" changes spacing at Bar"
I notice when I use the scroll wheel, it seems to expand the spacing starting from the Right end of the chart.
Is there a setting where it expands and contracts the spacing starting from the spot I have placed my mouse?
Thank you
[2022-09-29 15:44:14]
John - SC Support - Posts: 38768
There is not a setting to change how this works. It is the way it is.
The option of changes spacing at bar is the functionality you are looking for. So you just need to hold the "shift" key when you scroll and it will adjust from where you mouse is located.
