Date/Time: Thu, 26 Dec 2024 13:30:51 +0000
Increase Number of Ticks Seen for Bids/Offers on the DOM
View Count: 442
[2022-09-29 12:58:39] |
connordw - Posts: 44 |
Is there a way to increase the number of ticks that show for bids/offers on the DOM? Right now it only seems to show about 100 ticks of orders in each direction. Apologies if this has already been answered...haven't been able to find it on the support board. Thanks.
[2022-09-29 15:42:20] |
John - SC Support - Posts: 36850 |
Refer to the following for possible places where it has been limited: File Menu: Not Receiving the Full Number of Market Depth Levels What is the specific symbol for which you are having an issue? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-29 17:26:10] |
Perfect, thank you for the help. The issue was in Global Settings >> Sierra Chart Server Settings >> Max Depth Levels was set to 100. Changed it to 0 and it gave me what I needed. For ES futures.
