Date/Time: Thu, 26 Dec 2024 11:06:17 +0000
Point and Figures Chart input questions
View Count: 377
[2022-09-28 17:37:01]
User577576 - Posts: 2
(1) How and where do I go about changing the inputs for Point and Figure "box size" and "reversal size"?
(2) and is there a way to make those inputs ("box size" and "reversal size") automatic based on a formula of average true range?
[2022-09-28 20:47:44]
John - SC Support - Posts: 36850
1. The Box Size and Reversal are set in the Chart >> Chart Settings >> Bar Period >> Setting option. When the Bar Period Type is set to Point and Figure the Setting field takes the input for the Box Size-Reversal. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#IntradayChartBarPeiodSettings
2. There is not a way to do this with built-in tools, but you can develop a custom study that will do this for you. Refer to the following:
ACSIL Interface - Custom Chart Bars
