Date/Time: Tue, 26 Nov 2024 14:20:58 +0000
inaccurate P/L reporting
View Count: 1268
[2014-05-19 13:52:25] |
User66233 - Posts: 1 |
Hello, It seems SierraChart does not display P/L correctly. I've place 2 long trades, 2 lots each. http://screencast.com/t/nlkTCu1Zd http://screencast.com/t/SykGsfBTFEeM http://screencast.com/t/gI0i4ghFJ http://www.sierrachart.com/image.php?l=1400507412714.png Thanks Den |
[2014-05-19 20:52:50] |
Before we go over this in detail, update Sierra Chart to the latest release with Help >> Download Current Version. There were two problems that might be contributing to this, that were solved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
