Date/Time: Fri, 27 Dec 2024 02:03:41 +0000
Tool quick load
View Count: 525
[2022-09-28 00:01:22] |
clibanez - Posts: 10 |
I would like to know if there is any way to click on a line and be able to load the TC1 TC2 with a keyboard shortcut
[2022-09-28 14:20:06] |
John - SC Support - Posts: 36873 |
There is not a way to do it with a Keyboard Shortcut. But what is available is the ability to add the Configuration options to the right-click menu for the drawing shortcuts and therefore be able to right-click and select a specific configuration through the menu. Refer to the following: Global Settings Menu: Customize Chart Drawing Menu (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
