Date/Time: Sat, 21 Dec 2024 12:38:26 +0000
no P/L or NPL with currrency
View Count: 404
[2022-09-27 17:18:24] |
Ken Smith - Posts: 58 |
I switched over EURUSD from the ES and now when I take a trade it doesnt register the PL or NPL ? Thanks Ken |
[2022-09-27 17:32:08] |
John - SC Support - Posts: 36808 |
You should be getting some indication of P/L, but it might not be in currency. What exactly are you seeing? Also, refer to the following for how to set the P/L display: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-27 17:40:32] |
when I place a trade it shows the number of contracts ie: 2@.958.15 but the PL changes from red to green or vice versa as price changes same for NPL, only color change, but no dollar amount of gain or loss I have the format set to Currency value (C) & points (P) |
[2022-09-27 17:49:35] |
Check the setting for Trade >> Chart Trade Settings >> General >> Display Profit/Loss on Position Line and make sure it is set to Yes. Also check the setting for Trade >> General Trade Settings >> General >> Common Profit/Loss Currency and ensure it is set to a particular currency. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-27 18:00:07] |
None of those made any difference, but thanks John
[2022-09-27 18:09:43] |
John I think it could be in the symbol settings So, I just switched to the 6E and I thnk its the same currency pair I was using, and by going to 6E it now shows the PL and NPL, thanks again Ken |
[2022-09-27 21:17:17] |
Can you give us a screenshot of what you see with EURUSD? When we use this symbol we get the P/L display unless the above options are not set.
