Date/Time: Tue, 18 Mar 2025 17:40:41 +0000
Free Trial Request
View Count: 390
[2022-09-27 16:35:16] |
User231754 - Posts: 11 |
I have not Traded in awhile and when i last used Sierra Chart i was using Package 3 with AMP with CQG data. I think this is the Only Data i can use through AMP...Please let me know I Need a Free TRIAL so i can get Sierra Chart set up on my New Computer. I have already downloaded Sierra Chart but Cannot get any Data or Free Trial Started. Also for Future Reference do i Need to have Package 10 with AMP with Their CQG data. I Need to make sure Exactly what i Need to sign up for when i get through with the Free Trial. Just so you know i Only Used "Top of the Book" CME Data to Trade with and Package 3 before. Help me get set up so i can Trade with Sierra Chart again Please. |
[2022-09-27 17:01:49] |
John - SC Support - Posts: 38768 |
- We have reset the trial for your account, so you now have access to the full functionality of Sierra Chart. - There is no problem trading with AMP using CQG for order routing. To do this, however, you will need to be on one of the Integrated packages (Package 10, 11, and 12). We made a change awhile ago such that the integrated packages are necessary in order to make any external connections with Sierra Chart. To setup Sierra Chart to work with CQG, you will need to follow these instructions: CQG Trading Platform Service: Setup Instructions - We no longer support data from CQG into Sierra Chart, therefore you will need to use our Denali Exchange Data Feed. Refer to the instructions at the following link to setup the CME Group data from our Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
