Date/Time: Tue, 18 Mar 2025 17:35:46 +0000
Display value from chart on 2nd instance
View Count: 345
[2022-09-27 16:04:41]
rondawes - Posts: 39
I'm attempting to use Text Display For Study from Chart. The chart I want to pull from is in a second instance of SC. Possible to do this? I'm guessing the instances are isolated and it is not possible but maybe I'm missing something. Thanks.
[2022-09-27 16:57:42]
John - SC Support - Posts: 38768
You can not do this. As you state, the instances are each their own copy of the software and there is not a way to have them "talk" to each other.
