Date/Time: Fri, 02 Oct 2026 10:47:22 +0000
can this be done...
View Count: 646
| [2022-09-27 08:41:39] |
| User849502 - Posts: 481 |
Morning John, Is it possible, if you have a big bad computer that can, go back and get data on this chart for bonds waaaaaaay back to 2014 when they last were trading here? See attached chart. Thanks for your time as always. Karen |
| [2022-09-27 10:08:10] |
| Sierra_Chart Engineering - Posts: 25027 |
Yes there is Intraday data available for CBOT bonds back in 2014. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
