Date/Time: Tue, 26 Nov 2024 14:44:41 +0000
Lines Moving
View Count: 857
[2014-05-19 12:04:44] |
infpz - Posts: 826 |
Can you assist? Attached is a screenshot of what I had mentioned about trendlines that are placed at a certain level one day and after shutting down and re-opening the chart the lines and drawings are moved to a different location on the chart. Not sure why this happens. |
[2014-05-19 18:23:51] |
Is this with the Cumulative Delta Bars study? If not, then refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails34.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
