Date/Time: Tue, 26 Nov 2024 14:46:00 +0000
Missing historical data - GBPUSD 0855 - 1125 BST today
View Count: 1283
[2014-05-19 11:58:46] |
Trint - Posts: 115 |
Hello Sierra, As title really, missing historical data on Pound/Us Dollar pair for the above time. It doesn't look like it's Sierra Chart as it seems to be from the data provider. Just thought you might be able to ask them about it. |
[2014-05-19 16:55:05] |
We will check on this.
[2014-05-19 17:02:45] |
We are not noticing any missing data for this symbol for the SC Forex Data (FXCM) service. What Data service are you using?
[2014-05-19 17:32:50] |
It was the SC Historical delayed Intraday data that was missing.
[2014-05-19 21:52:03] |
Missing Forex data for that particular service, we cannot easily help with. We recommend for Forex data to use the SC Forex Data service: http://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
