Date/Time: Sun, 22 Dec 2024 11:15:56 +0000
data limiting not working as expected
View Count: 340
[2022-09-26 15:57:33]
RychieAllen - Posts: 7
pick $inx, so there shouldn't be intraday or historical merging of start/end dates.
focusing on date range logic and intraday and weekly view: we have two pairs of dates.
date range in file is set wide, let's say 1980-01-02 to 2022-09-23
data limiting method is set narrow, to prescribe what i want to see of my index.
result: i see the entire index to bloody weekly from some arbitrary date to the most recent.
How do get this to respect my data limiting method?
Just a moment, this software is great but i need to do all kinds of avoidances which takes lots of effort.
i would expect some help on this in the support issues but searching doesn't seem to help me, generally.
this makes progress very difficult due to curse of a thousand gotachas.
[2022-09-26 16:28:31]
John - SC Support - Posts: 36808
What you are doing should work fine. In particular, if you are limiting the data on the chart by using the Chart >> Chart Settings >> Data Limiting >> Date Range.
Let us know what you are using for the Data Limiting Method and what the values are set to. Also, what exactly does not appear to be working properly for your setup.
[2022-09-27 09:59:23]
Sierra_Chart Engineering - Posts: 17595
These are the relevant settings that you need to set:
Chart Settings: Load Data Limiting Method: Date Range >> Date Range From / To (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Date Range menu)
Make sure both the From and To dates are set.
Date Time Of Last Edit: 2022-09-27 10:00:22
