Date/Time: Tue, 18 Mar 2025 17:38:14 +0000
Small data gaps in Denali CME feed
View Count: 384
[2022-09-26 12:04:53]
01110010 - Posts: 33
I have been looking back at some low timeframe intraday data from 2022-02-10 for ES on a backadjusted continuous volume based rollover chart setting. When I look at a 5 second chart, I can see small gaps where bars are missing, e.g. from 13:02:15 to 13:02:25 UTC the 13:02:20 candle is missing.
Here is 13:02:15 highlighted, then in the next image showing the immediate next candle to be 13:02:25 rather than 13:02:20 as expected:
https://www.sierrachart.com/image.php?Image=1664193785770.png
https://www.sierrachart.com/image.php?Image=1664193819714.png
This isn't the only spot where I've found these small gaps, is there anything that can be done about this? Thanks.
[2022-09-26 12:53:33]
User431178 - Posts: 616
Not a data gap, just means there was no trade activity in that time period.
Chart Settings: Include Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu)
