Date/Time: Wed, 15 Jan 2025 08:28:15 +0000
Convert old Chartbooks
View Count: 1273
[2022-09-25 19:57:53] |
Chad - Posts: 234 |
Hi SCE, I just found out that Chartbook files > 2 years old, won't work with newer versions of SC. Per your documentation, I've attached those files here, with request that they be converted to be compatible (I'm currently running v2419).
Date Time Of Last Edit: 2022-09-27 14:56:04
Private File |
[2022-09-26 08:20:03] |
Sierra_Chart Engineering - Posts: 17953 |
Since there are many Chartbooks, it is best that you update/convert them yourself. Here is the documentation for that: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-26 17:47:15] |
Chad - Posts: 234 |
Okay, so just open then save in v2363 (or 2204 if 'older'), and opening anew in any instance versioned newer than that will work?
[2022-09-26 21:13:22] |
John - SC Support - Posts: 37226 |
If version 2363 will work for you, then yes. Downgrade (or install another copy of Sierra Chart) to version 2363 and open the chartbooks and save. Then open in whatever version you want. If you need to go back to 2204, then open in 2204 and save. Then open in 2363 and save. Then open in current version. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-27 14:55:24] |
Chad - Posts: 234 |
Hi John, Your final sentence was what I figured...much appreciated for your confirmation. |
