Date/Time: Tue, 18 Mar 2025 17:38:13 +0000
Second Instance and Open Orders Alert
View Count: 331
[2022-09-25 16:37:46] |
TriStar Trading - Posts: 151 |
I just started using a second instance in Live Mode and the second instance when I close always alerts I have open orders with my trade service. I always hit "Cancel Orders" and the alert stil occurs. Is this a problem? There really aren't any open orders I presume? Thanks, Mike |
[2022-09-26 10:12:34] |
Sierra_Chart Engineering - Posts: 18824 |
If you are getting that message you definitely will see the orders in Trade >> Trade Orders Window in that instance: Trading Information Windows: Trade Orders Window Do not cancel them unless you really want to cancel those orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
