Date/Time: Tue, 18 Mar 2025 17:40:41 +0000
Programming for time slice order
View Count: 525
[2022-09-24 20:58:54]
User887126 - Posts: 84
What would i need to use to program for time slice order? For example, i want my algo to place 30 lots at certain price but i only want to submit 1 lot at a time (while the buy/sell signal is still valid) up to my maximum order quantity. When the buy/sell signal is not valid anymore, the program will stop and cancel the order.
[2022-09-25 14:10:32]
Sierra_Chart Engineering - Posts: 18824
Have you already developed this algorithm in Sierra Chart using ACSIL? Basically you use ACSIL to accomplish what you need. Refer to:
Automated Trading From an Advanced Custom Study
We cannot go into the specific program code to do what you need. That is something you have to work out. However, this can be easily accomplished.
Date Time Of Last Edit: 2022-09-25 14:11:21
