Date/Time: Tue, 18 Mar 2025 17:35:47 +0000
How do you change the Pivot Points settings globally for all levels?
View Count: 393
[2022-09-23 21:27:04] |
Techotomy - Posts: 104 |
There are ~30 different pivot points in the Pivot Points study. Say i want to change all the colors to blue. Do I have to individually change the color for each level individually or can you change this globally with one fell swoop?
[2022-09-23 21:43:03] |
John - SC Support - Posts: 38768 |
You have to change them individually by changing each subgraph. Refer to the information here: Chart Studies: Subgraphs Tab >> Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-24 19:31:52] |
Yikes
[2022-09-25 10:02:51] |
Sierra_Chart Engineering - Posts: 18824 |
You can easily modify the study to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
