Date/Time: Sat, 11 May 2024 16:42:46 +0000
How to reset TC1 and TC2 to Default settings
View Count: 2511
[2013-04-29 20:51:38] |
Learose - Posts: 1 |
I recently upgraded to vs 912 and unintentionally saved a TC 1 tool. I would like to resest back to empty or default and can not figure out how to do that. When right clicked it shows on the side the TC 1 -8 under the word Load. i would like to not load this. It is causing the Trend lines I draw on a chart to stay on the chart even when I change the symbol of the chart. Thank you for your help Lea Miller |
[2013-04-30 19:12:35] |
Please refer to the documentation here to configure a Chart Drawing Tool: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#DrawingToolConfiguration In Chart >> Chart Settings >> Advanced Settings 2 disable Show Chart Drawings for Different Symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
