Date/Time: Fri, 18 Sep 2026 20:53:33 +0000
Order Allocation to Trade Accounts crashes the app
View Count: 837
| [2022-09-23 18:22:13] |
| User587930 - Posts: 13 |
Hello, When using the Order Allocation to Trade Accounts functionality and I trade to allocate to more than one account, the app crashes. |
| [2022-09-23 19:43:12] |
| Sierra_Chart Engineering - Posts: 24890 |
Yes we have heard this when you are not using Windows and it happens when you are interacting with the Order Allocation to Account settings window. It appears to be a problem with Wine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-23 19:43:32
| [2022-09-23 20:10:36] |
is there another method to do this in the app? or perhaps by editing a file configuration?
| [2022-10-07 10:21:42] |
| ProfitableTrader - Posts: 22 |
Am having the same issue when setting up order allocation. Using Crossover for Mac and have latest version (2444 64 bit) of Sierra Chart. Can anyone share any workarounds? If the configuration is created and saved on a native windows computer and then later copied in Wine/Crossover, would it work?
| [2022-10-07 11:04:50] |
Yes: If the configuration is created and saved on a native windows computer and then later copied in Wine/Crossover, would it work?
| [2022-10-09 02:23:35] |
Thank you! I was able to setup order allocation easily on a native windows machine. What configurations(s) do I need to copy over to reproduce the same on another box?
| [2022-10-09 03:29:10] |
I copied the chartbook and the twconfig file over to my Crossover installation and it seems to work. Looking forward to see orders execute with this config when market opens! :-)
| [2022-10-09 11:02:18] |
Yes you need to copy this file: .twconfig
