Date/Time: Tue, 18 Mar 2025 10:09:46 +0000
show orders/pos can never be unselected
View Count: 429
[2022-09-22 16:29:09] |
RychieAllen - Posts: 10 |
take any chart, sim trading and select show orders/pos under trade menu. it selects but then i can't unselect it. result is that the orders/positions can not be suppressed from chart. this is difficutl when trying to view other studies. help me understand if their is any other squirely things that i missed |
[2022-09-22 16:37:08] |
John - SC Support - Posts: 38735 |
When Trade >> Chart Trade Mode On is enabled, then the option for Trade >> Show Orders and Position is automatically enabled and can not be turned off individually. To turn off the Show Orders and Positions, you need to turn off the Chart Trade Mode On. When Chart Trade Mode On is not enabled, then you can toggle the Show Orders and Positions on/off directly. Refer to the following for further information: Trade Menu: Show Orders And Position (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
