Date/Time: Tue, 18 Mar 2025 03:51:07 +0000
New Version Update
View Count: 424
[2022-09-22 14:27:33]
zacktodd47 - Posts: 5
When I try to update to the newest version it will not let me.
I have sent in my installer log so you can take a look at it.
My email is zacktodd47@gmail.com
[2022-09-22 16:20:51]
John - SC Support - Posts: 38735
You have the following in your log:
Error opening Y:\SierraChart\CrashReporter.exe. Windows error code 32: Sharing violation.
The implication of this is that you still had Sierra Chart running. Be sure you are not in Sierra Chart when you perform the update, including any Sub-Instances.
