Date/Time: Tue, 18 Mar 2025 07:29:43 +0000
Can't find setting for the Alert Sounds file
View Count: 311
[2022-09-22 13:12:36] |
User360283 - Posts: 514 |
going to Global settings the ??? what to select next ?? ie Global Settings > xxx? Thanks |
[2022-09-22 15:50:08] |
John - SC Support - Posts: 38735 |
Refer to the following instructions for how to setup an alert, including selecting a sound for the alert: General Settings Window: Configuring Alert Number Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
