Date/Time: Tue, 18 Mar 2025 08:45:44 +0000
old dom configurations
View Count: 878
[2022-09-22 00:43:46] |
Marlin46 - Posts: 34 |
As time has progressed I have created some Trading Dom settings, bracket settings that need to be permanently deleted. Every time I go to the Data file and delete those they reappear when when I restart the platform. Can you please help in how to permanently delete unwanted Trading Dom file settings? Twconfigs or other unwanted setups? thank you so much in advance.
[2022-09-22 14:11:15] |
John - SC Support - Posts: 38735 |
Normally you can just delete the files and that will take care of it. The only reason why they would appear again is if you have the files being shared with you, in which case they re-download each time you start Sierra Chart. We see that you have a LOT of files being shared with you. You can view the list at the following link: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies You will have to manage the list of downloads in order to get rid of the things you do not want. Or, you can turn off all downloads by selecting the button on the above page for Disable File Downloads. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
